1 - 3 of 3 Posts
Had my C,V for five years now “still love it” my question is There away to show fault code on the C,V without hooking it up to the digital wrench?
Fault codes will show up in the lcd readout panel, but you have to be careful. If there's a fault, don't turn off the bike, as this can dismiss the display of the fault. If the code doesn't take over the panel when it happens, click through with the left trigger until it does.
They show up as two lines of numbers. There's a phone app called Indian Diagnostics where you enter the numbers and it tells you the fault.
602221
Thanks Dr, out riding the other day and the check engine lit up but no fault code indicated, just wondered if there was a way to find the code without the digital wrench
1 - 3 of 3 Posts
