I have a 2018 Indian chief vintage just had it serviced. Get it back to the house. Gear up for a ride. And the chassis warning light comes on, bike won't start. won't even turn over has anybody seen this before? Code 524040
Kickstand is 520267...Check your kick stand
I suspect the diagnostic codes are all the same for all bikes with the Bosch VCM. So I don't see 524040 in my 17 service manual. I don't have an 18 service manual. I do have a 2020 service manual for the challenger.I have a 2018 Indian chief vintage just had it serviced. Get it back to the house. Gear up for a ride. And the chassis warning light comes on, bike won't start. won't even turn over has anybody seen this before? Code 524040
Doesn't your bike have 2 side covers?My 2015 has all the codes on the inside of the side cover. If you have cell phone it might be able to read it.
Im not sure. The bike went in for the recall on the gear sensor and a full service. The code you sent matches my display. I just ordered the 2018. Manual. And yes the start switch is not working. When you look in the riders manual" the ! Says chassis fault which brought me to the question I posted. My side covers do not have the codes listed on them. Thank you. Im guessing my start switch is junk.I suspect the diagnostic codes are all the same for all bikes with the Bosch VCM. So I don't see 524040 in my 17 service manual. I don't have an 18 service manual. I do have a 2020 service manual for the challenger.
So if my theory is correct then your code means this:
Did they do any handlebar work while it was in for service?
