I find the whole annunciator/sensor system to be buggy, affected by various events (cold temp, movement while starting, kickstand position, cold throttle blipping, & MORE.) -with a pwr-down reset often clearing the warning. Yeah it’s irritating, but my ride has never been effected.
Yesterday in Custer SD prepping to ride the Black Hills all day, it was 29F overnight & 35 at 9am. Started bike & idled for 10+ min to get warm... idled smooth with coolant slowly climbing thru 120F; then suddenly it ran rough & died. Various lights & diagnostic codes were visible. I did a full pwr-down, waited 15sec & restarted. Idled smooth and warmed to 170 but all lights/codes still visible. (certain lights we expect to be on during idle, then soon go out: ABS, etc.)
Shut down while we got geared-up.
Started again with lights/codes still displayed ....and went riding without any ride issues. As tire temp/pressure increased that light extinguished but all others remained ON. Did 70mi, stopped. Restarted, rode, Security light went out but then back on 5min later. CheckEngine light went off & stayed off, same with Chassis Fault light (codes disappeared too.)
Next stop, start & go... all lighted cleared.
Go figure.
No doubt the software needs to evolve, and/or Indian needs to use higher quality sensors.
Btw... I see guys get a bit freaked by the Low Fuel & Fuel Range indicators. That’s a very low priority “feature” for me; that calculation is effected by many variables & hard to get exact. Know your bike friends... mine runs a consistent 43mpg depending how I ride. ALWAYS reset a trip meter to ZERO when ya fill-up. I’ve pushed mine several times to 5.6, 5.73, and to 5.9 gal at top-off, exactly as planned. No that’s not my norm habit, but did it just to KNOW this engine. You can confidently ride a full tank to 240mi if in a tight spot, despite what the “miles to empty” say (I did 265mi with the 5.9g fill) ...or pick a more conservative # for you, 220 or 210 MAX. Bottomline: don’t worry if “miles to empty” or “low fuel” is flashing and you’ve only gone 185mi since full tank.
Ride On.
