1 - 2 of 2 Posts
I’ve seen videos on how to change the front brake pads, but have not been able to find anything on changing the rear? The fronts are pretty straight forward. Any tips on changing the rear?
Position the bike up on jack to get the most room for caliper access and also remove left side exhaust slip-on. Use a thin flat bar to compress the caliper pistons a bit for the extra clearance you will need for new pads. Inspect everything while removing the brake parts. Have fun with it!
1 - 2 of 2 Posts
