I think there are only 4 people that managed to get in on the initial release of Lloydz cams, so I don't think we'll be seeing numbers anytime soon for the Lloydz cam/112BBK combo.
There is a cam service tool (P/N: PF-52939) that is used to press down on the rockers and release the pressure on the camshaft. I asked my dealership about buying one and its apparently a "service dept only" item and not available for retail. They didn't seem too keen on my offer to buy them a replacement if they "forgot" it outside of the shop door one evening. LOL It actually looks like it would be fairly easy to make yourself. Its basically a flat bar that goes across two of the valve cover bolts with integrated spacers to prevent over tightening along with some "fingers" on the underside to press down on the rocker directly above the valve.
I wouldn't attempt to ride my bike the 2 hours to my dealership after installing cams. Now if you go to your dealership for the Stage 2 cams, then they'll obviously be able to download the correct software onto the bike. If you're having them install Lloydz cams (once they're available obviously) then it depends on wether they're a Lloydz Remote Tuning Center (RTC) or not. If they are, then they'll be able to flash the bike with the appropriate tune from Lloydz. If not, then you'll need to send your ECU off to get flashed.
