1 - 15 of 15 Posts
Hey folks,
Any recommendations on a mount anyone uses on their bike?
I use a Quadlock. You have to buy the case that suits your phone and a mount that suits your bike. It's very solid and wont let go no matter how rough the road.
I have a 7 plus and will more than likely keep the same size phone. I’m getting a USB plug kit so I can install it on my Scout Sixty. Figure a mount would only make sense to go with that .
I’ll check it out.
Thank you
I have the OEM rokform mount. Works great and I like the horizontal position of the phone. You also need to get a case for it. I have a iPhone 10xs max case was 30 bucks on amazon and mount was the same.
Rokform Crystal [iPhone XS MAX]... https://www.amazon.com/dp/B07GKWV3SK?ref=ppx_pop_mob_ap_share
Indian Motorcycle New OEM... https://www.amazon.com/dp/B06X17J4ZW?ref=ppx_pop_mob_ap_share
My wife has this case
Rokform Rugged [iPhone XS MAX]... https://www.amazon.com/dp/B07GLC19F1?ref=ppx_pop_mob_ap_share
Ciro3d phone/gps holder.
I opted for the handlebar mount.
Then used a 6ft charging cable for my phone and a Battery Tender USB adapter off Amazon to give myself power all the time.
Phone/GPS Holders | Ciro3D Products & Accessories
Easy to remove my phone with a twist of the screw-clamp. When clamped down it's cemented in place.
Only complaint is the ball joint needs to be tightened with a wrench a turn or two. I've gotten it as tight as I could with fingers and I could still move it. After an extra twist with a wrench it goes nowhere even at highway speed and gale force winds.
I use the Kuryakyn right now with no complaints. My son just bought a mount from RAM and it is great, may be what I replace mine with if I should ever need to.
1 - 15 of 15 Posts
