1 - 7 of 7 Posts
Has anyone removed their catalytic converter while the exhaust is still on the bike ? It looks like it would be pretty easy once the shields are removed. Of course everything would have to be covered to protect from sparks.
Some have managed to get the material out from the back, but it's a B*STARD and you'll never do a thorough job of getting it all out that way.
Long drill bit and long air chisel and mine was completely gone in a couple of hours. Not much fun but I don’t have a welder so this was the best option for me.
Reactions: 1ofeach
So help me out guys. I keep hearing about people trying to remove the catalytic converter. What is the purpose of doing this?
for me the only reason is to cut down some of the heat , I dont want to spend over $600 on a set of headers
I did mine while it was on the bike. I just cut a window probably 4x6 on the side, and used put a flat blade screw driver on the top of the material and pounded it in with a hammer and pried it down and out... had it done and welded back up in about 30 minutes.
The point is to let the motor breathe, the restriction creates a lot of heat and starves the motor....of course you should run a flash to help with the rich fuel mixtures post cat removal....I took mine out and love that my right leg doesnt start on fire when I stop now!
1 - 7 of 7 Posts
