Probably going to need an extractor tool....I believe you can get them at home depot
I do have tools. Unfortunately I can't get a drill in there to start it. Thinking Method 4 is the way to go If my buddy has the right welder. I forget what his is. Trying to do the least damage obviously. Method 7 is brutal, but I won't say I haven't used it in the past... Thanks, gave me a few ideas, I might try the chisel method. May get me most of them. The lower right one looks a little deep, may not have a chance there.Probably going to need an extractor tool....I believe you can get them at home depot
Drill with a 90degree head is probably your best option. I wouldn’t worry too much about the threads you will be mostly ok. Most likely have to re tap the thread. You may find with a good soaking of penetrating oil first, the stud may start to move as you drill.
Maybe better to put a nut over the stud and weld into the nut. Then you will not weld onto the frame.I would likely try to weld on another bolt and turn them out...they don't look deep you it should be too bad to get a spot weld in each side
30 years ago I had an old Honda with a bad speedo cable. I bought a new cable, but couldn't get the screw out that held the cable in place down by the hub. It was a phillips head screw, but was in so tight that the head stripped while trying to loosen it with a screwdriver.If you were close to me I'd invite you over and get them out. I'd weld to them to remove them. Less chance of messing up the threads and the frame. Surely you can find a good welder near you to get them out. They really shouldn't be tight at all since the heads are missing, just threaded pieces in holes now.
Picked up my Chieftain used. It was a rebuild from an accident and the front Highway Bar must have snapped off, since all four bolts are still in with no heads on them. Anyone have ideas on how to remove them without taking the front end off the bike? I can't fit a drill between the forks and the frame to even try to drill and extract. I'm thinking about trying to get a buddy to weld a nut on each of them since they are just about flush with the frame. Not sure he'll be able to get a welder in enough to do it though either. I did pick up a 90* drill attachment, but I don't want to mess up my threads, so I'm hesitant to attempt it this way. I'm guessing the floorboards are easy enough to remove to get to the lower ones, I just haven't tried yet. Any advice is appreciated.
Lower Left
Lower Right
Top Left
Remember the frame is alloy. You cannot weld onto the bolt. One trick is to glue a bush or the right sort of socket that will act as a bush for a fine drill to drill a perfectly centred hole in the remains of the bolt. Then drill larger sizes progressively. You will need to take great care. These are possibly high tensile bolts. Then easyout.Did ya try using an Easy Out?? Ya drill a hole in the center of the broken bolt/stud,then insert the easy out into that hole which you will then turn counter clockwise to remove it.Once it bites into the stud it should twist out.If it still doesn't wanna move,then try heating the area around the stud using a Burns O Matic torch.{just don't get carried away with the heat]
Then before you insert the new stud,coat the threads lightly with COPPER Never-seize cause the next guy that has to remove it,for whatever reason, just might be you. Dave!!!
Top Right
I would definitely first try the hammer and small, cold point chisel hitting it counter-clockwise. You might be able to start it moving since the bolt usually tightens by putting tension on the head and the frame. No tension on the head and it might just turn out. Soak in a penetrating solvent first and good luck.I do have tools. Unfortunately I can't get a drill in there to start it. Thinking Method 4 is the way to go If my buddy has the right welder. I forget what his is. Trying to do the least damage obviously. Method 7 is brutal, but I won't say I haven't used it in the past... Thanks, gave me a few ideas, I might try the chisel method. May get me most of them. The lower right one looks a little deep, may not have a chance there.
