1 - 7 of 7 Posts
I'm attempting to install Rizoma Club S lights. I'm following this article
Long-Term Indian Scout: Rear Fender Modification
I need help with wiring up factory lights to those lights. I don't think I need a module. I believe I can make them work with relays. What do you guys think?
I have 6 wires coming from bike, that I spliced. And my LED (Rizoma) only has 4
The rizoma lights has the 3 functions
-running light (low red)
-brake light (bright red)
-signal indicator (bright orange)
Thats how i chopped my rear fender.
Looks good. Too bad Indian don’t sell the front Bobber fender already painted the OEM Scout colors. I’d buy one.
I've only done the aftermarket LED's on the Bobber, the scout is different as the turn signals are separate from the brake light. I would suggest checking for negative sources. On the US bobber the Brake/Turn signal is actually a negative pulse so a relay is needed to convert it to positive for aftermarket lights to work. easy enough to check with a test light.
1 - 7 of 7 Posts
