1 - 12 of 12 Posts
Hi does anyone know the size of the front brake reservoir screws.
One of mine has burred and Indian will only sell the whole cover at a cost of £92 about $115.
Very expensive screw!
Thanks
You mean the two philips head screws that hold the cover in place? imgur.com/a/QSttxRg (edit: that's a metric ruler so appr. 12 mm)
Sent from my SM-G986B using Tapatalk
BDR thanks for the reply.
Yes, those ones.
I was needing the thread size. Do you happen to know that ?
Possibly M4x0.7 because I just happen to have my master cylinder covers and original screws in a bag here, and I compared them to #8 - 32 (1/2”) screws.
Looked almost identical except I couldn’t mesh the threads together, one being nonmetric and the other metric.
If I could find my thread gauge in my cluttered mess of a shed I would have used that to check.
Easier to stop in at the hardware store when I’m out tomorrow, just don’t count on it because I tend to forget things.
Discussion Starter #7
Thanks Long Road,
Yep I’m there too, need to write a list before I go to the store!
All but absolutely confirmed, found the zinc plated ones at Lowe’s just before they closed tonight.
I would think anyone replacing them would want stainless steel. Lowes didn’t have that.
Notice the slightly different angle of the heads.
593516
Reactions: BDR
Yes, definitely 12mm long Phillips Flat Head Machine Screws M4 x 0.7 threads on my 2018 Scout front master cylinder. Put the thread gauge on them and confirmed.
Same threads but 16mm long on Rear master cylinder.
Hmm. All 4 screws on my ‘15 scout are the same.
Thanks for confirming.
1 - 12 of 12 Posts
