1 - 12 of 12 Posts
I’m looking to see if anyone has found any products that fit the Scout bobber for a heel shifter that works with floorboards.
Also I’m looking for an external air cleaner. Preferably the round one. Im not referring to the air box under the fuel tank. The one on the right Side of the engine.
Thanks!
If you are using the Indian floorboards, the Aeromach shifter works well.
594177
I run the Aeromach shifter with Joker mini floorboards. i also have K&N filter on the side. I tried some bigger ones but this is the one I liked the best.
594183
594184
594185
Thanks. Think I bought it right from K&N #62-1580 think it was like $50.
Do you have any posts about the install? I love the look but would like to know the details if/ when you have time... I am “learning” to be mechanically savvy!
no pictures but I can explain how I did it. I bought a 1 1/4” copper pipe cap. Then I drilled a small hole in the center of the cap and used the screw from the piece I took off the bike. Then just put the filter on the cap and tightened the hose clamp on filter. Didn’t do anything that couldn’t be changed back to original.
Awesome thanks!
I run the Aeromach shifter with Joker mini floorboards. i also have K&N filter on the side. I tried some bigger ones but this is the one I liked the best. View attachment 594183 View attachment 594184 View attachment 594185
I also run Joker mini floorboards and I've been contemplating which heel/toe shifter to go with between Aeromach and RMP... Also, with that side air filter installed, does that mean you have an empty cavity under the tank where the stock air box was located??? If so, I wish a company would make a modified gas tank to use up that space and increase fuel capacity beyond 3.3gal... One can only wish...
1 - 12 of 12 Posts
