1 - 2 of 2 Posts
Is there a trick to removing the Bobber forks (2019)? I have the manual, but after following it ( loosen top triple pinch, bottom triple pinch and turn signal), I can’t get the tubes to budge. I’ve even ran a plastic shim into the gap of the triples to try and open them up. Never had ones stick this bad.
I gave them a shot of WD40 and am letting them sit tonight, but if there is something I’m missing, I’m all ears.
Thanks,
Mike
Discussion Starter · #2 ·
Just FYI - Key is to run a plastic shim into gap of bottom bracket and to make sure that all 3 bolts that hold on the headlight nacelle are very loose. That and some WD40 seemed to do the trick. Still needed shim to get the tubes back in though.
1 - 2 of 2 Posts
