1 - 8 of 8 Posts
Banned
Anyone here chop their rear bobber fender without doing away with it totally?
Thinking about chopping about 3/4 off but using the same fender and obviously tail light relocation.
If not share which fender you may have bought.
Thanks.
to do this you will also have to chop the rear subframe or remove it and figure out a new way to mount the fender.
Banned
Yeah man, I figure the best choice would be to chop it on the back side a slide it back but that is the main issue. I like the tank machine fender but nearly 1k plus paint I figure there has to be an easier solution.
I kinda did, bought tank machine clamp and made some struts. Not perfect but didn't cost me over 1000. It's not chopped by the way
Sent from my Pixel 4 XL using Tapatalk
Banned
This is exactly what I want to do I I'm pretty sure I asked you about it in the past. I assume you need to remove the tire correct?
What is it exactly u ordered from Tank Machine? I see ur running the stock tire . Do u know if tank machine sells the entire fender for the 240mm tire that they have in some of their bobbers ? Hard to get an answer .
1 - 8 of 8 Posts
