1 - 18 of 18 Posts
I'm planning to paint the chrome tank panel and saddlebag latches to match the Titanium Smoke soon (like the DH models) and have the chrome stator cover as well as the clutch housing assembly and the other chrome piece on the left side powder coated soon. Question....since removing the cam covers requires dropping the whole engine from the frame (which I will not attempt) has anyone found a spray paint / ceramic / 2 or 3 stage acrylic or other high heat paint that I can use there safely without worrying about it failing? Any advice appreciated as our busy season is winding down and I need something to keep my mind occupied!
Tire Wheel Plant Fuel tank Vehicle
Super Moderator
2020 Challenger
IMO, you'll never find a rattle can paint that will adhere & be tough enough. It may look good at first, but will not stand up to bug removal, solvents, etc. When the paint starts coming off/discoloring, you can imagine what that’ll look like.
I had a scuff on my powder coated engine guards and repaired it with black rattle can paint. It looked great initially, couldn’t even tell it had been repaired, but didn’t hold up. Wound up getting the engine guards re-powder coated.
I’d just leave them chrome and powder coat what you can remove easily.
I found chrome valve covers on ebay to have powder coated. I figure I’ll wait till they do a major service on the bike then have them slap them on while the motor is dropped.
Since these valve covers are chrome, I figured I’d leave some parts chrome and black out others. Right now it’s a good mix of black and chrome.
2021 Indian Challenger-base- 2016 Victory Highball
same here, i have a 2nd set of covers. waiting for Lloyd'z & S&S to drop their cams and some rider feedback before i go all in on the engine drop.
What kind of service are you planning where they'd have to drop the engine? I watched a video of a tech doing it online and it's a huge undertaking.
I have the parts in the event that a major service is needed. I’m sure there’s gonna be some service where the motor needs to be dropped at some point. I’ll be ready when that time comes
Discussion Starter · #13 ·
Looks good. What did you use?
After disassembling the grills and scuffing the chrome as good as I could I just used some semi gloss high heat Krylon spray paint I had purchased for touching up the black exhaust. Should last as this area never really gets touched. Titanium smoke Urethane / matt clear for the tank panel and bag locks should be here today so that'll be tomorrows project. Have a DH stator cover and V cover on the way. Not sure yet but I will probably have the clutch housing assembly powder coated black as the factory one is pretty $$$
Be careful when you reassemble the bag latches. If you do it wrong, the bags will lock with no way to get in. Double check the latch works before closing the lid. Ask me how I know.
I looked Into powder coating the primary cover but it looks like there’s a bearing in the assembly that needs to be pressed out. Above my pay grade.
Discussion Starter · #15 ·
Yep, already have the seal ordered for that bearing and I used to be a machinist so hopefully I can get that bearing out and back in when finished.....
Discussion Starter · #18 ·
Looks great! Did you just mask off the black part on the tank console?
The top section yes. I doubt it can be removed without destroying it. The rubber strip on the bottom I removed and used acetone to clean the gooey glue off the metal before media blasting it. Next is to decide what to do about the chrome piece on the stage 1 air box.......
1 - 18 of 18 Posts
