I have a set of the Indian oem heated grips - they were a freebee when I bought the bike - and I'm not very impressed with the function against the price. Yes, they are slightly larger and they do produce heat but they are very expensive.
My brother and I have fitted the Koso Apollo (Technoglobe in the EU) heated grips on several bikes and they are better. They have a bigger range of heat settings and a discrete control button at half the price! Seek them out. Others on this forum have fitted them too.
When it's cold enough to use heated grips the roads probably aren't in the best shape. The last thing you want to do is take a hand off to adjust a he…
www.revzilla.com
@Jonty03 sorry to necro post but I need some advice if possible
I ended up getting the Koso Apollo grips for the wife and have installed them. Unfortunately, the first time she left them on by accident, the advertised features.....
"Low Battery Warning ensures the motorcycle has enough power to start
Grips automatically shut off if bike voltage drops below 11.5V for >5 seconds"
Did NOT work, and the battery was completely flat by the next morning. Not happy, but what can you do?
So, I want to connect them to a switched plug. I have found a 3 pin plug that is switched power (pictures attached) but unfortunately it seems impossible to buy a plug that fits this plug here in Australia. The only other plug I can find down near the battery (where I've wired the grips already and don't want to have to bother re-wiring the whole thing if I can avoid it) that has switched power is a weird 5 pin plug that I'm pretty sure would be for something else.
I was wondering if you or your mates could advise which plug to use and where it is located?
