1 - 15 of 15 Posts
I let my old bike go and didn't take the battery tender pigtail off. Is there any reason why I shouldn't put a cigarette lighter plug on my tender power supply and just plug it into the accessory outlet?
If your accessory outlet is still active with the key out, then it should work just fine. If it shuts off when you shut the bike off, it won't charge. ;)
my 2014 Chieftain has one attached from the factory, just pull ur left cover off (by ur knee), you'll see it!
I installed a battery tender lead that I can also use for a heated vest. I didnt see a SAE type lead in the wiring harness either. My bike is #610.
I just bought my Chieftain on 5/31......maybe its something they just started installing???
Its a true Battery Tender connection and located underneath the L H snap on cover behind the rear cylinder head
Can you post a picture of this connection? It's a SAE type of lead too? Thanks
Discussion Starter · #11 ·
Thanks, Vic. Mine definitely does not have it installed. I'm heading back to the shop tomorrow for 500 mile service and I will ask them, but I can do it myself later, or I may just keep the cig lighter attachment that I made. It was on overnight and seems to work just fine.
I think some of the dealerships are deciding to install the pigtail when assembling the bike.
Just one of those nice to have and easy to do during the assembly.
So hense, some have it, some dont
If you have a power outlet/cigarette lighter which isn't switched, be careful. Leaving anything connected can discharge the battery pretty quickly. My previous bike was setup that way and I would park it in the garage and occasionally forget to turn off the GPS only to find it a few days later with a dead battery (which ruined the batter). I finally installed a relay board connected switched by the ignition which turns off all the accessories (Outlet, GPS tracking transponder, seat heater, etc).
1 - 15 of 15 Posts
