1 - 4 of 4 Posts
I had the seat off for installing another item and decided to check the battery cables. About 2,000 miles ago i added star washers under the bolts plus dielectric grease. They needed a bit of tightening but for the most part were tight. I think the washers must have helped for anyone looking for a solution to continuing bolt loosening , this should help.
For the RM it's pretty much self evident if you follow the negative cable. It's attached to the right side frame.
Ya I figured it out. The problem was that I unscrewed the bolt that attached to the none battery side And fell off when I removed the battery side negative. I day to do some research and bingo. Lesson learned look it up before you start removing bolts. Thanks though I appreciate the effort, next the scraping sound from front tire.
1 - 4 of 4 Posts
