I had to get rid of my Barnett clutch cable. As the original poster described, I was not able to shift into neutral. The problem persisted through dozens of adjustments by me and the dealership's Indian certified mechanics. This included properly measured adjustments and tiny, tiny adjustments. After two weeks, another problem popped up: now I was able to shift into neutral, but only when shifting down from 3rd gear; I would need to shift up to get back into second.
Installing an oem clutch cable solved the problems.
I suppose it is possible my particular Barnett cable was bad, but that's not an experience I will be repeating.
dustbeard - glad you were able to resolve your issue.
