1 - 10 of 10 Posts
Installing the ILL-IND-FR on my 2014 Indian Chieftain. Seems simple enough, except for the KEY ON (+) Power & Ground... What component does this get plugged into? Unless I'm missing an open connection somewhere I the harness. Thanks for your help!!
600521
German Rider
Normally there is the same plug (male/female) behind the headlight and right fork tube in driving direction. It could be wrapped in black tape to, but the plug should be there. The changed the plug from oval to square in 2019, but as you stated yours is a 2014, it should be all connections plug and play.
Cu,
Sven
Reactions: Kreston and RACNRAY
German Rider
Installed in 30 minutes, also. Looking at the LEDs in running light mode, do they flicker as early LEDs did? Mine does, but I can't see them when I'm riding.
German Rider
All LED do that. Even headlights. Some faster, some slower. As stated, a lot of cameras show this, while taking videos with 30fps. If possible, try 60fps and mostly it is gone.
Cu,
Sven
German Rider
As long as you have Stock LED turn signals, it should fit/work. The Modul is a tad bigger than the size of matches(Streicholzschachtel).
Wir können das aber auch "zuhause" besprechen......
Cu,
Sven
1 - 10 of 10 Posts
