1 - 6 of 6 Posts
I have a 2016 dark horse. Put aux lights on. When powered up right side comes on. Start up and then both lights come on. Push aux switch off and right stays on. Will not shut off on the right.
Are you sure you have the right side plugged into the correct wire. You may have got it attached to the aux power wire instead of the aux light wire
Will check. There was 2 plugs. 1 said aux. The other one didn't have anything marked on it. Tried both,both do the same.
That one easier. Just the bulb plug was tucked way back behind wires. Dont wanna do that again. But I got it. The other one in plain sight along with left one. And they look the same.
1 - 6 of 6 Posts
