1 - 8 of 8 Posts
flying down the road trying to loosen my load.
It's Done
EXP Rekluse Clutch
Pingle Electric Shifter
and
shazam - one bad ass very fast scout that you don't need to use the clutch lever or toe shifter to ride.
Hah, very cool. So you still shift with your foot but there's no clutch? How do you come to a stop?
Sent from my ONEPLUS A3000 using Tapatalk
Gold member
No thank you! Not at this time! No more wheelies or bum starting (just Incase)! I’m waiting for running on tap water to happen.
A rekluse can still be disengaged manually- the clutch handle still works. At low RPM it automatically disengages, then you can take off just like a scooter, gas and go. If you want to rev-and-dump to ruin your rear tire, that works too. But with a judicious wrist, you can launch perfectly, every single time, and kill it off the line.
I know hydro clutch Rekluse setups can be bump started, you just spin the adjuster on the slave cylinder all the way out, then it functions like a traditional clutch. Not familiar with how they work on cable clutches, but assume there has to be an adjustment somewhere to compensate for clutch stack wear.
1 - 8 of 8 Posts
