1 - 7 of 7 Posts
I want some of my custom lighting and charger turn on automatically when the engine is running and turn off when it is not running to save the battery.
I am thinking to use some custom relay and cut into headlight (or some other light) to use as signal to distinguish that the engine is running.
Maybe, there is some advices for the easiest way to do that. Would be perfect if there is some solution where I can make no damage to existing wiring.
Any advices appreciated.
I have Chieftain 2016
Bronze Member
Another option is to use a power distribution block that allows you to run multiple accessories off of switched power.
Thanks for the link. This box looks nice. Maybe I will buy it to avoid creating the same by myself. But I still need to find the place to plug it in.
German Rider
Normally, there is a free ignition switched plug behind the right fork tube. It is hidden in black duct tape.
Cu,
Sven
Reactions: Eugen
1 - 7 of 7 Posts
