1 - 20 of 36 Posts
In my ~1500 miles of ownership I've hit the 5th to 6th false neutral 3 times and I read that the scouts have this issue but haven't seen anything about it on the FTR. Anyone else experiencing this?
I had it too, twice in 3500 miles. I blame a lazy left foot.
What could help is adjust the lever a tad down and make sure the linkage is lubed.
It’s because it happens when you’re hard on the throttle shifting into 6th above 6k generally.
Leisurely riding it won’t do it.
So I had this happen once last week and twice today when I was hard in the throttle and shifting into sixth gear... caused me to hit the rev limiter and display shows it's still in 5th, but I'm almost certain that I had fully engaged 6th gear. I'll try adjusting the linkage slightly, not sure how my ankle will feel about the new position... but if it resolves the 5th-to-6th false neutral then I'll give it a go.
Clicked up on the shifter with the same force as every other gear change before it, and even felt the "click". I don't baby this bike, if it only happened once I would think okay my mistake, but it's obvious the toe shifter either has some play in it or needs to be adjusted. I just want to resolve the issue so that it doesn't cause me to have an accident or damage the engine.
I've had the same happen to me a couple times in the 2-3 weeks I've had my FTR. Both times was when I was accelerating faster on it and it happened around 5-6 rpm.
Do we think switching the foot shifter will make a difference mechanically or would it just be a case of my foot just having to travel less for the shift? I find the current position generally ideal for how my foot rests over/under it so ideally wouldn't want to change it.
I agree with Max, if your a lazy shifter you’ll find a falsely between them all...but dropping the lever will definitely help...If your having trouble...👍😎🇦🇺
Thanks mate, will have to give it a shot soon as I'm in my new place where I can get my tools out to play :D
Had this 5-6 shift problem several times. I'm not a fan one bit. I feel a transmission from a large company, such as Indian, should never have this problem.
I'm guessing it's something I can't bring to the dealer for a warranty issue. Seems like it's an inherent design issue and the Indian mechanic wouldn't have a way to fix it anyway. He would just put in new replacement parts that would continue with the same issues. Sound about right?
I’ve had it too, though to be fair I’ve had it on a Ducati Monster with a quickshifter going from 5-6. Imagine having a wide open throttle then shifting, only to get a false neutral.... Bounces off the rev limiter pretty quickly.
1 - 20 of 36 Posts
