1 - 3 of 3 Posts
I want to install a GPS on my SRR. I have a Motorrad IV (Garmin Zumo 660) on my R1200RT that works great. I saw there was an accessory fuse in the fusebox (Indian says don’t use it in the manual?). I didn’t see an obvious place to tie into it and I didn’t want to tear the airbox covers off to look for a pigtail or connector. Do any of you know if there is a pigtail, or connection point for the accessory fuse? The other option is to direct wire to the battery but that means I take a chance in running the battery down if I leave it on the bike or forget to turn it off. Sometimes the GPS turns itself on (maybe only on the BMW?)
Thanks!
Mark
There’s an SAE connector on the left side of the bike behind a panel (for charging the battery), I plan to run my GPS off of that.
Thanks, I pulled the right side off but not the left. Sounds like it’s super easy.
1 - 3 of 3 Posts
