1 - 6 of 6 Posts
So is there such a thing? After I changed slip on mufflers from the Vance & Hines to the RC Componets I have noticed on heavy throttle from 4th into 5tf ill get a pop on occasion. My set up is Stage 2 cams PVCX , canned Craig B tune, decatted stock head pipe lloydz air intake and RCX slipons
I have a 15 RM and with the big bore kit and factory stage 2 exhaust and I have always experienced popping between shifts on moderately accelerating, it’s caused by cold air being drawn back into the hot system with just the right amount of unburdened fuel
Recently completed the stage 2 cams and have I/P stage 1 muffs, Wimmer A/C, PV3 also with canned FM/GraigB tune. I get an occasional decel pop, and will get a rare pop when when up shifting. Up shift pop is between gears when I change gears slowly, and as said it is rare.
One more good thing about the stage 2, I no longer get the annoying ting ting ting sound of the exhaust prior to full operating temp.
I get popping sometimes, usually when I'm just floating on the throttle riding with slowish traffic. I've got AC and Stg1 pipes, 558 cams, PVCX with a CraigB tune.
I've not noticed it when changing up, but I've still got the original cat so that might make a difference.
1 - 6 of 6 Posts
