1 - 6 of 6 Posts
My abs light is on and stays on with my 16 Roadmaster. I've read that it should be on until you reach a certain speed. Some have mentioned that sometimes the sensor needs cleaning. I took my front off and did just that. Same result. Now in have not tried the back yet. All it is is a piece of plastic. Are these known to have issues and how much to have the dealer replace them (or purchase myself and install?)
Below is a picture of the gap between the sensor and the abs ring
Sent from my SM-G930W8 using Tapatalk
Discussion Starter #2
Nobody with a similar problem? Its going to the dealer next week and afraid they are going to tell me I need to replace both sensors
According to the manual, the ABS lamp should go out when your speed exceeds 6 MPH. A disconnected connector or broken wire may cause the light to stay on. Doing a thorough checkout with an ohm meter may be what you need.
1 - 6 of 6 Posts
