So on Friday I rode my Chieftain after a few days of it sitting. ABS light stayed on after getting above 10MPH. No codes shown on the dash as I toggle through the screen. No check engine light either. Toggled to the voltage screen showing 14.4 to 14.7 volts. Assuming the values shown are correct? Shut bike off hit the power button on the tank console, toggle to the voltage screen and showing around 12.7 volts. Start bike and voltage temporarily drops to 11 volts and bike starts the same as always with voltage resuming to around 14 volts at idle. I have spent a fair amount of time on the Tech Q&A looking for a similar situation. Guess the first thing to do is check both sensors to see it they are dirty, check face on the two toothed rings on the wheels, look for wire chafing. Bike has 49+K miles battery replaced last summer. Not sure if anyone else in Indian land has had the same thing. Thanks
