1 - 4 of 4 Posts
has anyone tried to convert their teardrop headlight to led. My low beams just blew and they don't make this style headlight any longer and I wanted to keep this style.
Try and determine the type of socket the bulb uses. The socket types are usually describe by a number. Find the number and look on Ebay. They have LEDs for just about everything.
It simply and H4 or H8, I can't remember, which one. But all you need to do is replace the bulb. And check you nacelle grounding wire while you are in there. They are known to come loose...
1 - 4 of 4 Posts
