1 - 1 of 1 Posts
Did a little bit of searching around this and a lot of posts are showing that people speedometers aren't working. Mine went out and stopped working for a short time, at the same time as this I could not turn the bike off from the dash power.
I reseated my computer plugs and now the speedo and power switch works fine but still reads the same ABS code as above. Tested brakes and yes they lock up now.
i checked my center plug on my PCM and looks as though I'm getting a bad connection on one of the pins (Pictures) The wire that comes out is a thicker red wire which shows as PCM 1- VCM power.
the other VCM harnesses seem fine.
could this be related or is it just a pinched wire/dirty sensor?
TIA
-Shippy
594120
Office equipment Vehicle Bumper Metal
1 - 1 of 1 Posts
