I'm genuinely shocked at what you guys are paying; why not invest in a manual and do it yourself, you could even buy a ramp and tool kit for what some have paid on here. Or just search youtube for numerous videos on servicing jobs.
An oil and filter change is so easy on these bikes, takes about 10 minutes, use same spec non Indian oil and filter and it only costs about £40, no specialist tools or ramp required. The RM even has an oil service reset on the Ride Command so no need for a dealer to do it like other brands.
I changed the front brake pads yesterday, takes 10 minutes a side and cost £22 for the the brake pads (EBC), no specialist tools required, a very simple job, the rears are just as easy.
I also changed the tyres this week, accepted you need a lift for this, removing the front mudguard is the most time consuming job, thereafter the front wheel comes out easily, the rear is even easier to remove, just pull the shock pin and lift the bike, no need to remove exhausts etc. I then take the wheels to an independent to have the tyres fitted.
Regarding the belt, I would tackle this myself too but if no sign of damage at 30k I would continue to run it, I see no reason why it should not go for twice this mileage.
Fork oil I know requires specialist tools to get them apart, but again I would pull the forks myself and take them to the shop.
I accept you pay a lot of money for the these bikes and many want to look after them by the book and if you can afford to do that using a main dealer then that's great, but many like me cannot afford to do that. These are simple bikes to work on for the majority of service and maintenance items and you can save a fortune by doing it yourself. I also appreciate some also worry about warranty, unfortunately for me as there is only one dealer in the country I live (Scotland) the cost to get to the dealer and back just pumps up the expense and at least I know the jobs done right. Of course we are all screwed if digital wrench is required and we have no choice but to bend over and take it at the stealer.
