Sadly the rear header is different on the 2022, Factory rear pipe is higher and different shield mount spot, the cat mounts are also different.
This means oem or aftermarket headers from the 2019 will not work with the 2022, unless you buy the rear exhaust section, which means pulling the tank, even then it’s a guess.
Toce have already altered their 2019 full system to work with the 2022.
And Ryan at Lloydz has ecu v6 flash tunes available for the 2022.
Top picture is the 2019, bottom is the 2022.
My guess is to make access to the one clutch cover bolt easier, that was previously half behind the old pipe.
