1 - 8 of 8 Posts
So new Indian owner here I just picked up a 2021 Scout(not the bobber) and I wanted to see if anyone who has one or knows for certain that an exhaust for a 2020 will fit? Everything I have found says yes but doesn't hurt to check with the community at large. I don't see any mention of routing or bracket changes.
I am just gonna bite the bullet and take the risk. Thanks for those who replied
So for anyone who wants to know yes 2021 seems to be the same. Worth noting I went with Bassani Slip-ons which sound good however the bolt they supplied is way too short. So if you plan on buying them make sure to get a longer bolt I went with a 2inch(what I had on hand) and used a couple washers to shim it out slightly
Reactions: WENDIGO
The exhaust systems on the 2015-2017 are different from the newer exhausts. Later units have a slightly different rear pipe angle and subsiquenent muffler mounting.
1 - 8 of 8 Posts
