1 - 4 of 4 Posts
Is the rear suspension on my 2019 Chief DH adjustable? Dealer says no and owner's manual says yes (vaguely)
I have a 2015 CDH so assuming you have the same suspension set up then yes it can be adjusted. If you remove the seat and side covers to reveal the rear shock you will see a large portion of the shock body is threaded and has two large ring nuts on it which are notched. You will need a "C" Spanner to fit the nut, the top one is a lock nut so simply loosen it off then adjust the one below to increase or decrease the preload on the shock, once done tighten the lock nut down.
1 - 4 of 4 Posts
