1 - 4 of 4 Posts
Hi all, sorry if this has been mentioned before, but I can'f find the answer. I want to put a 21" wheel on the bike. I spoke to my dealer and they say it will fit as long as the bolts line up (IE the wheel is made for the Indian Chief) and I can reuse the brakes, ABS ring and fender.
Is this true? I had seen some people say I need a new ABS ring. any advise on those that have done this? also would like recommendations on 21 wheels anyone has used.
Thanks in advance.
thanks for the quick response. so the fender adapter is only if I want to use the original fender or is it for aftermarket ones too? I'm looking at the Klock Werks fender.
you only need it for the OEM fender, not the klock werks one. I modified the OEM one (took a grinder to it)
Tire Automotive tire Spoke Alloy wheel Wheel
This picture is of the modified OEM fender, pre finished up.
1 - 4 of 4 Posts
