Did you pull apart those pins, clean and lubricate them, as this is a spot where they could be binding. Also, the piston on the caliper needs to be cleaned, and if it has never been done, flush out the old brake fluid. The combination of these three things can have your pads not retracting from your rotor. This is why they smell hot, and your rotors are hot to the touch.I got the EBC 377X as per their docs for my 2016 model. I was able to get the caliper out and had a hard time with the pins. There are 4 of them, two outer and two in the middle underneath and you just need to take these off. I struggled with the outer ones. š¤¦āāļø. You can press the caliper bracket and the outer pins go lower and you can pull the pads out.
The brake line has a clamp held by a screw about a foot from the caliper. Taking this screw off gives you more play to work on the caliper and you don't need to take the exhaust off.
On the caliper, there is a set screw on the outside for the botton two pins which come off and then you can unscrew the pins. I used a C clamp to push the piston back and I was able to replace the pads. Test ride went well. I could smell something hot near the caliper and the rotor felt pretty hot, is this because of the new pads? I will test again and see if this continues.
I searched a lot of posts and YouTube videos for a 2016 Scout but almost all of them had later models. It looks like the 2015 and 2016 models have a different caliper, pins etc. I'm posting it here as it might help others.
I also replaced the front ones with FA672HH and it was not difficult.
your caliper pins will slide in and out with little effort, if they have been cleaned and lubricated. I like to use Never Seize on them, and burnish it into the metal, then some hi-temp grease inside those boots on the pins.
āCharlie
