Hi everyone so I did purchase this 2015 Indian Scout with what was indicated as a bad ECM and Radiator.
The Indian dealer stated that the rear aftermarket taillight the p.o put on is what shorted out the ECM.
He said the the p.o put a standard bulb and tail light and that the Scout was all LED which blew the ECM. Hmmm dunno about this.
He mentioned it also needed a new rad, ok I can handle the R&R of that.
There was also a safety check done and it listed a cracked crankcase on the left side by the shifter linkage.
Investigating this it appears the crack is at the outer edge of the left motor mount. One large bolt goes through this support.
Question? Can this spot be welded?
Thanks for any help folks.
