1 - 7 of 7 Posts
Hello guys n girls , I need Help ! Just got back my vintage Le from dealer after adding stage one exhaust , awesome but now it won't start , battery says 12.3 checked plug connection , I'm losing my mind , dealer is 120 km away ,suggestions / answer ? Thank you so much
The bike wont start if the kickstand is down and bike not in neutral.
Did they maybe mess up the switch some how when installing pipes?
If you have checked the kickstand and checked the kill switch... turn the key on and put the bike in first and roll it forward a little bit with the clutch out... then turn the key off... then go thru the starting sequence again... let us know what happens.
If the battery is only reading 12.3, you probably need to put it on the trickle charger and get it back up closer to 14. If it's around 12, it won't start.
I'll try it with kick stand up but have always been able to start it with it down , I'll try also rocking it forward when I get home , thank you both so much I'll try out the suggestions ,when I get thru the door
1 - 7 of 7 Posts
