Guy's sorry but I had to re-register something was wrong with the site. Anyway I'm in need of Clutch Pushrods on both sides and an adjuster Screw. Does anybody know if they can be substituted with anything from a HD or other? Thanks in advance!
In the middle of the pressure plate is the clutch adjuster screw. Directly behind that is the clutch rod or aka clutch push rod. Directly behind that is the right side push rod with the oil slinger. The ramp pushes the right side into the left side and adjuster screw causing the clutch to disengage. I need those rods and the adjuster screw. Make sense? 😀What are clutch pushrods? Are you talking about the springs or the flange bolts? I can likely help you, but I don't understand your terminology.
The other parts are shown here but these are not for the Spirit. I'm trying to find out if there are any crossover parts that will work.#8 The others aren't shown here. Let me see if I can find them. Thanks for trying to help!!! I appreciate it !
