Every so often when I push the starter on my 2002 Chief it binds and the starter does not kick over it seems to bind. Any thoughts of what might be the problem? I do have a new fully charged battery.
I know it sounds simple, but make sure your battery connections are tight. If they are just a little loose, I have had that symptom. Other than that, that's my best from here.
Hello, I read your post that I may nead one of these in the near future and there is a link to Indian parts. What part are you talking about?
Thanks,
Roger
ALSO!! Ya might wanna check your battery negative cable where it connects to ground on the frame rail [follow the battery negative [ground] cable and it'll take ya right to it] to make sure it's tight.This has been a common problem which has raised hell with the electrical system.So that should be your starting point.
