1 - 4 of 4 Posts
2000 Indian Silvercloud All of a sudden my low beam quit, so I go get another bulb. That didn't do the trick. I checked voltage and there is only 8 volts going to the low beam side. My side lights also don't work because of the low voltage. My high beam works fine and I have 13 volts on it. Does anyone have any suggestions of where to go from here?
Check the ground at the Nacelle. Those were notorious for coming loose.
It's a lithium battery and voltage is good on it.
I have good voltage at the switch so my next step is the relay if I can find it
Discussion Starter #4
A big thanks to Mark at Aardvark Cycle. He hit it right on the head. He's gotta be the smartest guy I know about Indian Motorcycles. On the 6 pin connector under the module, the plastic around the pin had melted for some reason. I cleaned the plastic out around the connector and it works fine.
Thanks to you guys for trying to help
1 - 4 of 4 Posts
