This hole is necessary to get the sand of the core out of the spoke, after casting.What is the other hole, opposite the valve stem, on the inside of the rim for
The difference with the rimlock hole is that it goes all the way through so you can bolt it up when the tire is in place. The TPMS hole doesn't go right through.On dirt bikes and when running a low tire pressure it’s for a rimlock
