1 - 13 of 13 Posts
Rode the Scout to work today, first time out in darker conditions.
Bulb in the speedo went out, had to rely on streetlights & traffic flow for speed.
What type of bulb does it take & how is it accessed?
Thanks
Recently replaced my burned out speedo bulb on my '01 Chief. Electric speedo, not mechanical.
If it's the same, you should be able to gently pull/pry the speedo out of it's home in the console.
The bulb stats are printed on the base of the bulb. I used a red LED bulb that had the same stats. Popped it all back in, and has been working fine. If you run with a stock replacement, it uses a red sleeve (bulb condom?) to make it shed red light. Mine shredded when removing it.
I don't see any way to shimmy the speedo out. I pulled the 1 bolt in the 'dash' and the trim didn't seem to budge.
Does the entire panel between the split tank need to be removed to get to the back of the speedo?
Not my photo, but here is the Scout 'dash', removing the 1 bolt here didn't seem to do anything. Didn't try to remove the bolt down by the seat.
Mine just pried out with my finger nails. ? Maybe try a plastic putty knife.
Make sure you loc-tite those dash screws before riding. They will back out on you from vibration.
Got it pulled apart. Had to remove both dash bolts & get it lifted enough to disconnect the speedo cable.
No idea what the replacement bulb is though.
Searching online, a #74 wedge seems close.
It looks like the socket only contacts 1 lead on the bulb.
I'm glad you figured out as much as you did. Sorry I couldn't be of any help. My speedo is electronic, not mechanical. ?
I took a look at Indian Moto, and didn't see the bulb to replace yours. I hope you figure out where the power is interrupted, and that's all you need.
Discussion Starter · #10 ·
Will need to trace the wire & find where it's losing power.
Multimeter is showing nothing at the socket.
That, or run a new wire for the speedo bulb.
Guessing I'll need to empty/pull the tank to get to the wiring. Seemed awful tight in there when I pulled the 'dash'
2001 Scout same no power to the speedo light nor the fender light. Disconnected the speedo cable and the lights came back on. As soon as the drive cable touches the speedo housing lights go out. So far no luck finding the problem.
1 - 13 of 13 Posts
