Who has changed out the Scout grips/or plans to do so?
Discussion in 'Indian Scout Guides and How-To's' started by Transylvania, Jun 16, 2015.
  1. FlCruiser2302
    FlCruiser2302 Junior Member
    Jan 6, 2017
    183
    26
    28
    well then, the bell shall be lowered, can't mess with traditions! Thanks for letting me know!
  2. FlCruiser2302
    Jan 6, 2017
    183
    26
    28
    I bought all three together, I like the way the fork wraps look as well.
  3. FlCruiser2302
    Jan 6, 2017
    183
    26
    28
    Wo
    wow, who painted the tank emblem, that is awesome?!
  4. FlCruiser2302
    Jan 6, 2017
    183
    26
    28
    Wow, all the discussions about performance suspension and you just showed a picture of the exact opposite! How does the bobber seat take the excess shock? I am guessing the sprung seats I have seen from Mothers(?) would work well too, but that set up would not work for a passenger, huh?
  5. Rudy Smith
    Rudy Smith flying down the road trying to loosen my load.
    Nov 23, 2014
    2,030
    802
    113
    Mobile, Al
  6. Rudy Smith
    Nov 23, 2014
    2,030
    802
    113
    Mobile, Al
    I just tied some anti demon soup cans (empty) to my rear fender with a string - sorta like those just married things. seem to work fine.:cool:
  7. Meggie
    Meggie Gold Member
    Nov 4, 2014
    3,901
    4,619
    113
    Dallas
    Wanted a rigid, got myself a rigid... No passengers, ever.
  8. brougham79
    brougham79 Junior Member
    Sep 25, 2016
    52
    45
    18
    Jacksonville, FL
  9. sergio88w
    sergio88w Junior Member
    Dec 3, 2016
    283
    54
    28
    CA
    These are the grips I got on my motorcycles.
    Black ones are Avon 3 ring with LED bar end light on my Scout. Brown one is a old school style with tennis leather grip and LED bar end light on my Kawasaki cafe racer
    • Like Like x 1
  10. thegent
    thegent Member
    Nov 28, 2015
    471
    123
    43
    Edinburgh UK
    fitted Scout oversize grips, tried them today ... very comfy, a huge improvement over the stock grips, which I found too narrow..
    was going to fit heated grips, got sidetracked with these, they come with integrated throttle tube which was a big plus for me.
    [​IMG][​IMG]
    [​IMG]
    [​IMG]
    • Useful Useful x 1
  11. sergio88w
    Dec 3, 2016
    283
    54
    28
    CA
    I installed the same grips on my cafe racer build
  12. Liam1288
    Liam1288 Junior Member
    Sep 22, 2015
    138
    16
    18
    Hi guys has anybody changed to these grips?
    Keis Heated Grip Accessories | Keis Apparel
    They are 7/8 in diameter though i have doubts that they will fit over the throttle tube?
    Clutch side would be fine as its just the 7/8 handlebar end though on the throttle side theres the handlebar plus the throttle tube... which im guessing pushes the diameter up a little?
    Any thoughts?
    Cheers
  13. thegent
    thegent Member
    Nov 28, 2015
    471
    123
    43
    Edinburgh UK
    it would be normal for 7/8" grips to be 7/8" clutch side and wider than that throttle side.
    I changed to the Indian oversize grips. Stock throttle side came out with the tube when the 4x screws were removed ... remember its orientation, it needs to go back on aligned the same way. I had to cut the clutch side off. When you've removed the throttle side you should be able to cut the grip off and refit the heated grip. It may need trimming down to get the heated grip on the tube, don't know ... haven't done that bit (my throttle side grip came on a throttle tube). When you've got the heated grip on the tube it should fit back in the assembly and then you fasten the 4x screws.
    ps. have you thought of Oxford heated grips, they now come with a controller that turns the heat off when you stop the engine, so you can wire them direct to the battery ... they come with an inline fuse and battery connection. I have them on my Bonneville and the system works!
  14. Liam1288
    Sep 22, 2015
    138
    16
    18
    Thanks buddy!
    Ill ask the manufacturer if the throttle side has a bigger diameter.
    Yeah i saw the Oxfords but i dont like the large control unit.
    Integrated control in the grips look a lot better imo and worth the extra money i think
    Liam
  15. Barender
    Barender Junior Member
    Aug 19, 2016
    32
    2
    8
    Atlanta
    Are the grips 7/8 or 1 inch?
    Thanks
Share This Page
Search tags for this page
indian scout grips
indian scout handlebar grips dimensions
indian scout leather hand grips
