Pcv or pvcx
Discussion in 'Indian Scout Performance & Suspension' started by mr2dogz, Jan 11, 2017.
  1. mr2dogz
    mr2dogz Junior Member
    Sep 9, 2016
    24
    9
    3
    Hi all
    I've been looking at the pcv and the pvcx and I am not to sure which one is better.I have just fitted a full vance hines s/s exhaust system and a trask powerflow filter.I was going to put a pcv and have the scout rolling road tuned but now seeing the pvcx I am not sure.Any help would be great.
  2. TheChad
    TheChad IndianMotorcycles.net Gold Supporter Gold Supporting Member
    Nov 29, 2016
    332
    140
    43
    Tampa, FL
    Lots of threads about this... See Reflash vs. PCV?
    Personally, I like the idea of having the control the Dynojet PVCX offers without having to install a piggy-back system. Flash it and remove it. You do lose any on-demand tune options, but I'm ok with that. I have a list of mods I want to do myself to my '17 Roadmaster and the PVCX was the first thing I ordered... Get it tomorrow (from FuelMoto). Figure even without any mods I can put a fuelmoto tune on it and cool it down a bit.
    Next steps:
    1. Cat-less header - Maybe true duals, maybe stock minus cat, maybe fuelmoto jackpot... will see
    2. Vance and Hines turn downs.
    3. Indian AC or maybe some other AC
    4. Cams
    Figured I'd to all of these myself except the cams.
    Bottom line, I think it's a matter of preference... My 2c
    • Like Like x 1
    • Agree Agree x 1
  3. PrometheusVII
    PrometheusVII Junior Member
    Sep 5, 2016
    254
    114
    43
    Las Vegas, NV
    It really depends on how deeply you intend to get into the "Tune" of your bike. The PCV is very straight forward, but it is a "Piggyback" system. That's not a bad thing, the PCV is a well vetted proven performer, I have 2 on Victory bikes, never a "real" problem.
    I say "real" problem because my wife had a problem where if she attempted to start the bike and it failed, and sh immediately went for a restart, the bike would sputter and run like hell. If she shut it off after a failed start, just for a second, then restarted, it ran fine. Turns out the PCV needed a quick moment to reset between starts. By the way, my HID module does the same thing on my bike, too quick and it doesn't light. After figuring this out, neither of us has had a problem.
    The PVCX just reprograms a facet of the existing Bosch electrical that run our bikes. Not only does it offer us and our well paid technicians the ability to adjust things like throttle response (and many more, I just can't think of them off hand), but it is not a piggybacked system. You plug it up, flash you new tune, disconnect and off you go. And if you don't like the change, do the same to reinstall your old tune. And if you change/upgrade parts in the future, just find a tune online (buy through Fuel MOTO, they are developing a substantial database for a wide range of parts and combinations, also stellar customer service), install said tune and you're done.
    The nice thing is you have it narrowed down to two of the premier systems for this job, so IMHO it's win win either way. Best of luck, keep us posted. Cheers!
    Start, Ride, Repeat...
    • Like Like x 2
    • Informative Informative x 1
  4. mr2dogz
    Sep 9, 2016
    24
    9
    3
    My indian dealer wants me to go down the pcv route as they have a rolling road they want £500 which is just over $600 or I can pay just under £400 for the pvcx.
  5. TheChad
    Nov 29, 2016
    332
    140
    43
    Tampa, FL
    +1 on the FuelMoto Route... Even if you go the PCV route. If you search this forum, you'll see Jamie from FuelMoto is VERY engaged and I've heard nothing but positive regarding their customer service.
    Not sure I fully understand what "rolling road" is... but seems like a no briner for PVCX? Cheaper and it's under YOUR control.
    • Like Like x 1
  6. Drydock
    Drydock Member
    Mar 28, 2016
    310
    123
    43
    Osage Co. MO
    I think that's what we call a Chassis Dyno. As you can also do a Dyno tune on the PVCX, I'd just get that. I also reccomend FuelMoto. With the right software the PVCX gives you access to a lot more parameters as well.
    • Agree Agree x 2
  7. rds040800
    rds040800 Junior Member
    Dec 16, 2016
    64
    18
    8
    Liberty, TX
    I went with the PVCX. I didnt want to mess with any wiring or having to deal with a dyno to get a PCV where it needed to be. Well worth the money even after a small hiccup after I flashed it. Tech support from Dynojet was quick to respond with a remedy to my situation.
    • Like Like x 1
  8. DarkHorse666
    DarkHorse666 Member
    Dec 30, 2015
    371
    188
    43
    Burbank, CA
    I don't have a strong opinion about the subject, but if you twisted my arm, I'd have to say:
    PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX PVCX
    • Funny Funny x 4
    • Like Like x 1
    • Agree Agree x 1
    • Winner Winner x 1
  9. Drydock
    Drydock Member
    Mar 28, 2016
    310
    123
    43
    Osage Co. MO
    Well heck 666, if you're not sure . . .
    • Like Like x 1
    • Funny Funny x 1
  10. 2SITH
    2SITH Junior Member
    May 11, 2015
    166
    26
    28
    Las Vegas
    I ended up with the tuner from tier 1 tuners as they have the only tuner of its kind in the market. The owner is really knowledgeable and his partner helped start dynojet.
    • Like Like x 1
  11. bstewart63
    bstewart63 Junior Member
    Feb 27, 2016
    82
    32
    18
    St. Louis, MO
    I would think the PVCX is the best way to go. Fixing the intentional throttle plate roll back at 6K on the 60's is a pretty good advantage. Being able to read and clear DTC's is also a huge plus.
    • Agree Agree x 3
  12. RaWarrior
    RaWarrior Junior Member
    Nov 27, 2016
    94
    26
    18
    The fact you don't have to install a PVCX is worth the slight price bump over a PCV alone. Plus you can reprogram the drive-by-wire and a host of other parameters that you cannot with the PCV.
    You can read and clear DTC's through the speedometer as well. If the check engine light is on, pull the trigger until CK ENG is displayed, pull and hold the trigger and the code will display. Pull trigger to scroll through multiple codes if there are. Pull and hold when a code is displayed and it'll clear.
    • Like Like x 1
  13. rds040800
    Dec 16, 2016
    64
    18
    8
    Liberty, TX
    The fact it pulls DTC codes is what made for an easy remedy when I had an issue. Saved me a big headache of troubleshooting, so well worth it for the added bonus of being able to pull codes. My speedo would not show the code like it was supposed to.
    • Like Like x 1
  14. mr2dogz
    Sep 9, 2016
    24
    9
    3
    Well I think my mind is made up pvcx is going to be my next purchase.thanks for all the help :)
    • Like Like x 1
  15. CraigB1960
    CraigB1960 IndianMotorcycles.net Gold Supporter Gold Supporting Member
    Aug 28, 2016
    819
    519
    93
    Tucson, AZ
    One often forgotten benefit of the PVCX is the retention of accurate MPG calculations.
    • Agree Agree x 2
Share This Page
