Air Shock - Hose Extension
Discussion in 'Thunder Stroke 111 Guides & How-To's' started by rickkcir, Nov 23, 2016.
  1. rickkcir
    rickkcir God Bless Texas
    Jan 21, 2014
    2,789
    1,746
    113
    Greenville TX
    I've been wanting to do this for three years... finally. Hows that for procrastination?
    I'd ordered an 13" Stainless Steel hose ages ago... but .. .realized the 'bend' wasn't working for me enough to get the cover on over it. I sat it aside months and months ago... basically forgot about it. Then Read somewhere, someone had used an adapter hose meant for duallys... basically, has a 90' bend on one end ... would work.. so I bought a package. But.. too short ( 9" ) . So, I got a 90' elbow to use with the original hose... and .... perfecto' . Cover closes tight, all good. For now, I've got it just 'laying' there in the space behind the rear jug..... don't see an issue with it for now. Only negative with this setup.... would be hell checking that air pressure when the motor is hot!
    • Like Like x 3
    • Useful Useful x 1
  2. Bow1340
    Bow1340 Member
    Aug 22, 2014
    531
    246
    43
    PA
    Love the idea of doing this but can't get past the issue that this introduces two additional potential leakage points. Will be anxious to hear from you in a month or so how the system is holding air. Hears hoping you have great results!
    • Like Like x 1
  3. rickkcir
    Jan 21, 2014
    2,789
    1,746
    113
    Greenville TX
    Wondered the same thing... but... damned thing always needs air anyways when I check it for 2 up riding ( never check it when solo ) .. so .. figure I haven't lost anything. Holding air as I type this with no leaks... I'll do some daily checks.
    In a perfect world, one would bypass the hose off the shock itself w/ a replacement... if this doesn't give me satisfactory results.. that's next
    • Agree Agree x 1
  4. T120R69
    T120R69 Bronze Member
    Dec 3, 2014
    1,356
    308
    83
    Westfield, MA
    Now if you could add a quality pressure gauge in line that would be visible without removing the side cover that would be the Cat's But.
    • Like Like x 1
    • Agree Agree x 1
  5. Roadmaster03
    Roadmaster03 Junior Member
    Aug 13, 2015
    221
    137
    43
    image.jpg Added a 15" extension to mine 8 months ago, mounted it to the tab that holds the O2 sensor wire which I no longer needed as I have the dobeck fuel controller.
    Made a heavier gauge tab as the original was paper thin, leaks down about 10 lbs after 3 weeks or so, I normally keep it to 70lbs riding 2 up.
    • Like Like x 2
    • Winner Winner x 1
  6. T120R69
    Dec 3, 2014
    1,356
    308
    83
    Westfield, MA
    Did you have any leak down prior to the modification?
  7. T120R69
    Dec 3, 2014
    1,356
    308
    83
    Westfield, MA
    Also, where did you get the 15" hose with the 90 deg end?
  8. Roadmaster03
    Aug 13, 2015
    221
    137
    43
    Straight 15" hose that I connected to the existing line off the shock.
  9. Roadmaster03
    Aug 13, 2015
    221
    137
    43
    Leak down on stock valve was about 20 lbs every week, I found out the schrader valve was leaking, I changed it when I added the extension.
    • Informative Informative x 1
  10. T120R69
    Dec 3, 2014
    1,356
    308
    83
    Westfield, MA
    Renewed interest on extending the hose, where to find the hardware is the first problem. :(
  11. Wyattsdad
    Wyattsdad Member
    May 31, 2016
    751
    253
    63
    SF Bay Area and North
    If you guys want to keep track of your time I think you will find that the time/effort expended in eliminating *the need to remove the side cover far* exceeds the time you would have spent *removing the side cover* over the course of owning the bike.
    I mean it's 2 seconds off and 4 seconds back on, that's it.
    WD./
    • Agree Agree x 1
  12. T120R69
    Dec 3, 2014
    1,356
    308
    83
    Westfield, MA
    The time isn't the point! It has to do with making a (perceived) improvement to an almost perfect ride that doesn't require any dealers input. Another words make it your own.
    • Agree Agree x 1
  13. Ride2much
    Ride2much Member
    Dec 24, 2014
    314
    329
    63
    Idaho
    My other ride has similar tabs holding on the side cover, after a few years of occasional removing, the tabs broke off. On my RM, I must remove the left cover two or three times a week, depending how much my wife wants to ride, I can't imagine the tabs holding up. Have your priced a new side cover $$$$
    • Agree Agree x 3
  14. rippy
    rippy Member
    May 5, 2016
    622
    191
    43
    The cornfields of eastern Iowa, USA
    Evidently you didn't put much thought into your smart ass reply.
    Edited to clarify. This was a reply to a post that has been deleted at some point. My post Quoted the smart ass reply, but now the quote has disappeared with the original post.
    • Agree Agree x 2
    • Funny Funny x 1
  15. rickkcir
    Jan 21, 2014
    2,789
    1,746
    113
    Greenville TX
    Disagree. My heat shield is in the way. Fringe on the seat is in the way. Bag on they Hwy bar is in the way ... Lid on the hard bag is in the way .
    Good news.. is .. that f***r will never fall off on its own.....
    • Agree Agree x 2
Share This Page
Search tags for this page
indian chieftain airshock extension hose
